I am setting up the fuel system right now and started by removing the front tank and sumping the rear. The rear tank will still have the stock pickup and intank 255L/hr pump with a 255 L/Hr frame rail for everyday driving. When I go racing, the front tank selector will turn on the Weldon 2025A and that will feed the turbo under boost. Here is the tank after it was sumped with two #12 AN ports.
Here is the view of the tank flipped upside down!
In order to make sure we can return enough fuel with the big pump, I installed a #8 Russell bulk head fitting for the return fuel.
Finally, the tank is installed with the return line capped for right now. Hopefully this is the last time to drop this tank!
The restraining straps are to prevent the Rancho Bars from hitting our lift. I am fabricating some straps for this next week!
