4lb lower,Eaton S.C. stock pulley,stock idlers,= P/N GAT-K080675HD Accessory Drive= GAT-K080991HD. These belts are a perfect fit!!
Usefull Info.. F+R Ceramic Break Pads,Front/Rear rotors/Seals/Bearings/Gates Belts from Nappa.Tried searchin forums Too much B.S. no P/N's Here you go
Rotors and pads are wrong part numbers.. Rear rotors P/N good,front rotor/hub assy. seals P/N good!!,front rotors and all ceramic pads above all wrong and bearings.When ordering bearings leave out the "P",bearing above good if u cheep,P is the cheeper bearings..Nappa has 3 rotors Regular,premium,ultra premium which are same as premium less paint for 50 bucks more!! Use premium rotors not ultra ,want paint u paint em LOL.When ordering parts from Nappa the 2004 lightning got lost and not in books.Use 2003 Lightning!!!!!And not 2004 heritage,I went with ultra premium not impressed,same rotors as premium less paint.Any other questions PM me.Beat down but my pain ur gain..Belts above are #1 best fit 1st class!!!Nothin like new front rotors and bearings,truck drives brand new and tight!!!!
