Results 1 to 11 of 11
Thread: Lightning as a tow vehicle
    Participating User dboat's Avatar
    Dec 2002
    The Big D
    We are going to Moab in a couple of months. I plan on using the Lightning as a tow vehicle for the Jeep. I will be flat towing. Am running a summer tune in the truck now.
    Ant suggestions? What trans temp should I be concerned about? It has plenty of tq to pull the Jeep through the mountains.
    If Terry is checking in, wonder if there is a tow tune I can load up?
    Dana
    Mods:
    EBC Rotors w/Kevlar Pads,PSP air kit,Bedrug,Snuglid
    Wet Okole Seat Covers,Accufab TB,
    Stolen Pioneer Head Unit
    Focal Speakers,Pioneer Amp,Silverstars
    FMS 1/2 Drop Kit, HRE Wheels
    REM oil separator,Line Mod Valve
    1st dyno 372.1 hp 436.94 tq @90 degrees!!
    Performance Research Enhanced
    2002 #42 out of 4726
    Build Date 11/14/01
    SCT Xcal2,Valentine 1 Hard Wired
    M20 laser jammer,Herbs washers,Tinted Glass
    PR Big Mouth Quiet Exhaust, Hotchkiss Sway Bars
    Extreme Dynamat, C&L plenum & elbow, 4# pulley
    Electric Fan, Ported Supercharger
    Oct 2003
    Houston
    Quote Originally Posted by dboat View Post
    Dana
    No problem with overheating when towing, especially with stock converter. The 1/2 kit may present problems with bottoming due to lack of adequate suspension travel, depends upon tongue weight and rear springs and shocks used.
    Dec 2002
    The Big D
    Thanks,since I am flat towing the Jeep, there is almost no tongue weight.
    Mods:
    Build Date 11/14/01
    Participating User tiffo60's Avatar
    May 2005
    FORT WORTH
    Thogg pulled his G1 everywhere with his G2, so you shouldn't have any problems, its usually good practice to not pull in overdrive unless your are on dead flat roads.
  5. #5
    Dec 2002
    The Big D
    Quote Originally Posted by tiffo60 View Post
    Thanks, didn't know about the not towing in OD except on flat roads.
    Sent from my iPad using Tapatalk
    Mods:
    Build Date 11/14/01
  6. #6
    TALON Supporting Member L8 APEX's Avatar
    Mar 2002
    The Lone Star State
    I'd say the only limitation to a Lightning towing is the tire rating. Otherwise it rolls on a F250 power train. You did say flat towing through mountains so braking could be a concern. toad braking options are pricey , hopefully you can keep speeds down and maintain control with downshifting and your brakes.
    "Greater love hath no man than this, that a man lay down his life for his friends.” -John 15:13
  7. #7
    Dec 2002
    The Big D
    Thanks Terry, the Jeep doesn't like being towed over 65, so lower speeds aren't a problem. Brakes are EBC, so they work pretty well.
    Mods:
    Build Date 11/14/01
  8. #8
    Dec 2002
    The Big D
    Made it to Moab. Weather was good and the temps didnt top 70 on the way out. Hottest the truck got was 190 for the engine and 188 for the trans. Intake temps were about 40 degrees above outside temps.
    Sent from my iPhone using Tapatalk
    Mods:
    Build Date 11/14/01
  9. #9
    TALON Sgt at Arms Moonshine's Avatar
    Mar 2002
    Living the dream in ShangriLa
    Good for you and the L. Moab's probably a good place to be at the moment.
    The dirty farm truck.
    '00 white Lightning #405
    12.84 @ 106.5 on street tires at full weight. Chip n Filter only mods.
  10. #10
    Dec 2002
    The Big D
    Ebola free.
    Mods:
    Build Date 11/14/01
  11. #11
    Dec 2002
    The Big D
    Well, made it home without incident, except for the Jeep on the trails, but that's another forum.. The engine temps got just above 200 when climbing out of the valley and the trans temp got up to 198 as well, but then dropped to 183 engine and 168 trans when a front came through and dropped the outside temps to around 50. Overall the temps stayed in the 185-190 range for the engine and around 170-180 for the trans for the most part.
    The brakes held up well, but we were careful to keep plenty of distance between us and those around us.
    Mods:
    Build Date 11/14/01
